Author Topic: crouch / p4t (for managers only)  (Read 4749 times)
Offline vito
« on: March 02, 2017, 06:09:31 am »
Nick used whilst ingame: vito_nice_guy
Time and Date that you were banned: today
Suspected Reason (if any): crouching and shooting
IP Address: 213.80.201.72
PAC ID: - (unregistered)
Admin that banned you (if known):p4t
Extra notes:
Crouching and shooting is allowed, it's not crouch glitching.
Crouch glitching is a variant of fast switching except the only difference is that a player crouches when doing so. Crouch glitching happens when a player crouches and fires a shotgun then quickly sprints away.
[09:38:35] p4t: don't crouch..
[09:38:39] vito_nice_guy: why
[09:38:44] p4t: stfu vito
[09:39:30] vito_nice_guy: crouch glitching (is a variant of fast switching except the only difference is that a player crouches when doing so) is not allowed, crouch is allowed
[09:39:42] p4t: crouching and shooting is not allowed
[09:39:46] p4t: I'm not debating it with you
<RastySpoon> [11] p4t: it's common knowledge in here that crouching and shooting is not allowed, with any weapon
It's not a common knowledge, it's bad practice to ban people for things is not disallowed in the rules. And it should be stopped, this is real reason why this post here. It's not my ban appeal.
I'm calling the managers to solve this problem of administration.
« Last Edit: March 03, 2017, 08:09:50 pm by Darfy »
Offline p4t
  • VC-MP Server Admin
  • awards VC-MP Most Friendly (2020)
Re: crouch / p4t (for managers only)
« Reply #1 on: March 02, 2017, 06:47:59 am »
Crouching and shooting has been disallowed for a long time.  You saw my name and decided to come in and try to mess with me, and it backfired on you.  I actually agree with you on one thing though - it should be listed clearly in the rules that crouching and shooting is not allowed (instead of falling under the "glitching" category).  I've suggested this several times in the past.
In the end you knew what you were doing, and you got banned for it after I warned you a bunch of times.  Not sure what you were trying to accomplish but if you wanted the rules to be changed, you could have simply brought it up in discussion in the forum instead of making an example of yourself by getting banned.  Seems kind of... counterproductive.
Anyway, you'll be able to come back in a few days.  I don't think 3 days will kill you, especially since the only time you ever come into the server is to either fuck up one of my events or feign ignorance and get yourself banned.
-Add me on PSN-
Offline vito
« Reply #2 on: March 02, 2017, 06:54:11 am »
I know how it was started by tarkan to ban people for this reason few months ago. And it's time to stop it.
You as being admin "suggested this several times in the past" and this were ignored. It's clearly counterproductive.
Offline p4t
« Reply #3 on: March 02, 2017, 07:08:41 am »
Interesting.  When I said crouching and shooting have been disallowed for a long time, you said "I know."  So you knew it was against the rules, but you lied about it in the server and got banned?  You're not helping your case here, vito.
A lot of advice comes from players and fellow staff about how to change the server and make it better, and a lot of that advice is forgotten or ignored.  However, unlike what you're doing right now, it's not counterproductive at all because it encourages discussion and new ideas.
Again, if you want a rule changed, this is not the proper way to go about it.  Try a different section.
-Add me on PSN-
Offline vito
« Reply #4 on: March 02, 2017, 07:20:02 am »
It's not against the rules http://forum.littlewhiteys.co.uk/index.php/topic,17633.0.html it's "disallowed" by admin's word.
So what exactly I lied?
Nope, I do not want to change rules, I want to make admins follow the rules not their own wishes.
Offline Darfy
« Reply #5 on: March 03, 2017, 08:04:42 pm »
I don't know why some admins are still under the impression that shooting while crouched is disallowed. Miscommunication, I guess.
Let's clear things a bit:
Back in 0.3z crouching and shooting with shotguns would cause glitches in fire rate as well as made it possible to skip the reload animation and that's the reason it was forbidden in the first place. The most easiest and simplest way was to disallow crouching and shooting in general, with any weapon, just to avoid confusion. This was clearly stated in the server rules at that time. (See post: http://forum.littlewhiteys.co.uk/index.php/topic,17633.msg200739.html#msg200739)
Later AdTec_224 came up with a proper solution and made it so that crouching with shotguns was disabled by the script. We then decided to remove the rule because the fix was functioning properly. (See post: http://forum.littlewhiteys.co.uk/index.php/topic,17633.msg222810.html#msg222810)
When 0.4 came out it fixed the shotgun behavior while crouched so the server-side fix was removed. I don't think we ever actually announced this change properly so perhaps some admins, especially those who were not here during the transition to 0.4, didn't really get the information. Like p4t for example.
Our bad. Use this post as reference for future cases to do with the matter.
Unbanned.
Edit: Also everyone make sure you don't confuse the two terms "crouching" and "crouch glitching" which are two totally different things. Crouch glitching is still disallowed as clearly stated in the server rules.
« Last Edit: March 03, 2017, 08:21:40 pm by Darfy »
