Author Topic: Any Solution ?  (Read 59496 times)
Offline BanJack
  • SA-MP: NO_MERCY
  • VC-MP: BanJack
Any Solution ?
« on: March 23, 2017, 11:35:33 pm »
Hello,
I installed GTA 5 on my laptop,
It was all good before I tried to lunch the game. An error appeared, which is : this file is not compatible with this version of your windows......
I have windows vista , 32-bit
After researches I found that the game "GTA 5" does not work on 32-bit , it works on 64-bit
So, do any of you have a solution for this problem ?
Thank you :)
Offline Myle
  • SA-MP: Myle
Re: Any Solution ?
« Reply #1 on: March 24, 2017, 04:36:05 am »
What's your PC spec?
Plus,Vista won't be able to run GTA V.If you can,upgrade it to Windows 7 or more.
There's always another way
Offline Frost
  • wtfffff i no kiddy fish wtfffff
    • http://littlewhiteys.co.uk
  • SA-MP: Frost_
Re: Any Solution ?
« Reply #2 on: March 24, 2017, 04:53:36 am »
gta v DO NOT WORK ON 32 BIT! DUH! so load your windows to 7 64 bit it will run if your PC meet the requirement. as myle said whats your PC spec.
running gta v in 32 bit is a bad idea. https://www.systemrequirementslab.com/cyri/requirements/grand-theft-auto-v/12455
« Last Edit: March 24, 2017, 04:56:12 am by Frost »
Offline Maddy`
  • ÃŒl Mìgìlòrè
  • SA-MP: Maddy
Re: Any Solution ?
« Reply #3 on: March 24, 2017, 05:35:13 am »
Get an Xbox or ps4, new games coming best 8)
Offline vito
Re: Any Solution ?
« Reply #4 on: March 24, 2017, 08:18:26 am »
I bet your laptop wont run gta v since it has only 4GB of RAM it's not a gaming laptop and GPU there would be not good for V too.
Re: Any Solution ?
« Reply #5 on: March 24, 2017, 10:05:49 am »
You most likely need a new PC or Laptop. If you've been preinstalled with a 32-bit OS, chances are your processor is 32-bit. Check whether your processor supports 64-bit, if so install a 64-bit OS, if not get a new computer.
Offline BanJack
  • SA-MP: NO_MERCY
  • VC-MP: BanJack
Re: Any Solution ?
« Reply #6 on: March 24, 2017, 07:17:26 pm »
my pc spec is vista
can I upgrade from 32-bit to 64-bit ???
Offline Myle
  • SA-MP: Myle
Re: Any Solution ?
« Reply #7 on: March 24, 2017, 07:52:13 pm »
When we said "PC spec",we actually meant the "Hardware Specification" of your current Computer.
We can only tell if you'll be able to install 64 bit OS,if you let us know your hardware specifications.
Re: Any Solution ?
« Reply #8 on: March 24, 2017, 10:19:04 pm »
Your processor type specifically.
Re: Any Solution ?
« Reply #9 on: March 25, 2017, 01:59:02 am »
my pc spec is vista
download 32-bit twice and it will be 64-bit
UmarxD
Re: Any Solution ?
« Reply #10 on: March 25, 2017, 04:23:32 am »
U can Right click "my computer" then click the last tab "properties" then write the processor info here.
Offline BanJack
  • SA-MP: NO_MERCY
  • VC-MP: BanJack
Re: Any Solution ?
« Reply #11 on: March 25, 2017, 10:47:43 am »
my pc spec is vista
Lolllll 😂😂😂
Offline BanJack
  • SA-MP: NO_MERCY
  • VC-MP: BanJack
Re: Any Solution ?
« Reply #12 on: March 25, 2017, 10:53:15 am »
Windows 7 UItimate
Rating : 3.5 windows experience Index
Processor : Intel(R) Core(TM)2 Duo CPU       p8600   @   2.40GHz
2.40GHz
Installed memory (RAM) : 3.00 GB
System type : 32-bit operating system
Pen and touch : no pen or touch input is available for this display
UmarxD
Re: Any Solution ?
« Reply #13 on: March 25, 2017, 11:30:41 am »
i don't think u can run gta V with that rating. but if u can, I'm not sure it will run smoothly.
« Last Edit: March 25, 2017, 11:34:14 am by â–²Pakimanâ„¢ »
Offline Renii
Re: Any Solution ?
« Reply #14 on: March 25, 2017, 11:50:46 am »
Windows 7 UItimate
2.40GHz
I have the same cpu and i cant run gta v
+3gb ram? Hmmm :p dont even try
