Author Topic: List of VCMP Commands | Vcmp_Config.txt  (Read 7097 times)
Offline salmanalvi.pk
« on: November 25, 2018, 03:34:07 pm »
VC:MP 0.4 Documentation
Values for vcmp_config.txt
This theme can help with some commands for own"VCMP" input and interface modules for all players and can be a reference
Note :
This file can be found in the folder you installed VC:MP to (C:\Program Files\Vice City Multiplayer\04beta_b1t1 by default)
By the way, the vcmp_config.txt file for the public beta is at (Vista, 7, 8 ):
C:\Users\<youruser>\AppData\Roaming\VCMP\04beta\vcmp_config.txt
OR
(for XP):
C:\Documents and Settings\<youruser>\Application Data\VCMP\04beta\vcmp_config.txt
game_antialias
Description :
Defines the behavior that VC:MP uses to antialias the game.
Allowed Values :
0: Disables antialiasing
1: Enables antialiasing
Note :
Antialiasing uses a significant amount of processing power, but makes the game look smoother. The VC:MP team only recommends enabling antialiasing if you can already run the game at 25fps on average, at minimum.
game_allowedmods
Description :
A list of mods (ASI files) allowed to be used.
Allowed Values :
Text, with each mod separated by one space, like so:
game_allowedmods mymod1.asi mymod2.asi mymod.flt
game_framereserve
Description :
Decreases the amount of time the game waits before serving the next frame. If your framerate is lower than it should be, increasing the value of this decreases the amount of time waited by the number of milliseconds specified.
Allowed Values :
Any integer (whole number) that is at least zero.
game_windowed
Description :
Determines whether or not to run in windowed or fullscreen mode.
Allowed Values :
0: Game will launch in fullscreen mode
1: Game will launch in windowed mode
game_menuonrestore
Description :
Determines whether to return to the menu after returning from being Alt+Tabbed.
Allowed Values :
0: Does not return to menu.
1: Returns to menu.
splash_loadbarbgcol
Description :
Sets the background color of the loading bar on the splash screen.
Allowed Values :
ARGB hex colors (AARRGGBB format)
See: con_fillcolour
splash_loadbarfgcol
Description :
Sets the foreground color of the loading bar on the splash screen.
Allowed Values :
See: con_fillcolour
con_fontname
Description :
The name of the font used in the chat console.
Allowed Values :
Text: the name of any font installed on your Windows machine.
con_typeloc
Description :
Determines the location of the typing area in the console.
Allowed Values :
0: Places the typing area on the bottom of the console, the style used in 0.3z R2 and earlier.
1: Places the typing area on top of the screen, the style used in the first public beta.
con_fontgap
Description :
Alters the size of the gap between letters in the chat console. Larger values increase the size of the font gap. Setting this to zero uses normal font gap size.
Allowed Values :
Any number that is at least 0.
con_fontscale
Description :
The relative size of the font as a multiplier. Larger values increase the size of the font. Setting this value to 1 uses the normal font size.
Allowed Values :
Decimal values that are at least 0:
Acceptable: 0.005
Acceptable: 1.500
Not Acceptable: -5.000
Not Acceptable: 12pt
con_numoflines
Description :
The maximum number of lines that appear when the console is expanded. The larger this value is, the more space the console takes up when expanded.
Allowed Values :
Any whole number (at least 0)
Note :
Setting this value to 0 hides the console entirely.
con_disappear
Description :
The amount of time, in seconds, it takes for each message in the console to disappear.
Allowed Values :
Note :
Hidden messages can be seen by expanding the console (see: con_openkey). Setting this to 0 disables disappearing messages.
con_logging
Description :
Determines what method VC:MP uses to log console messages.
Allowed Values :
0 - No logging
1 - Plaintext logging
2 - HTML logging
con_fillcolour
Description :
The background color of the console when it is expanded, expressed as an ARGB hexadecimal.
Allowed Values :
ARGB hex colors (AARRGGB format)
Example
con_fillcolour FFFF00BB
FF: Alpha hex value (opacity)
FF: Red hex value
00: Green hex value
BB: Blue hex value
con_openkey
Description :
The keycode of the key that expands the console.
Allowed Values :
Integers (whole numbers) -- see this list:
http://msdn.microsoft.com/en-us/library/windows/desktop/dd375731(v=vs.85).aspx
And convert to decimal here:
http://easycalculation.com/hex-converter.php
scb_scale
Description :
The relative size of the scoreboard, as a multiplier.
Allowed Values :
Decimal values that are at least 0 (see: con_fontscale)
scb_edgescale
Description :
The size of the edges (border) of the scoreboard, as a multiplier.
Allowed Values :
Decimal values that are at least 0 (see: scb_edgescale)
scb_edgecolour
Description :
The color of the edges (border) of the scoreboarrd.
Allowed Vales:
See: con_fillcolour
scb_fillcolour
Description :
The color of the background of the scoreboard.
Allowed Values :
See: con_fillcolour
scb_captioncolour
Description :
The color of the column titles ("Name," "Ping," etc.) of the scoreboard.
Allowed Values :
See: con_fillcolour
scb_scorepingidcol
Description :
The color of the values of names, pings, and scores in the scoreboard.
Allowed Values :
See: con_fillcolour
scb_underlinecolour
Description :
The color of the line underneath the column titles in the scoreboard.
Allowed Values :
See: con_fillcolour
scb_highlightcolour
Description :
The color of the highlight box behind your name, score, etc. in the scoreboard.
Allowed Values :
See: con_fillcolour
scb_serverinfocolour
Description :
The color of the server name in the scoreboard.
Allowed Values :
See: con_fillcolour
scb_countcolour
Description :
The color of the number of players on the server, which appears in the top right corner of the scoreboard.
Allowed Values :
See: con_fillcolour
scb_versioncolour
Description :
The color of the VC:MP version, which appears in the bottom right corner of the scoreboard.
Allowed Values :
See: con_fillcolour
scb_openkey
Description :
The keycode of the key that, when held down, displays the scoreboard.
Allowed Values :
tag_scale
Description :
The relative size of nametags of players. Larger values increase the size of the font.
Allowed Values :
tag_quality
Description :
Determines how well to render nametags of players. A lower value will make nametags more jagged and aliased, but may also increase game performance.
Allowed Values :
Decimal values that are at least 0.
Note :
The following is an example of tag quality, left being the lowest value:
http://i.imgur.com/5IK95EY.jpg
tag_maxdist
Description :
The maximum distance, in world units, away from a player at which their nametags will appear.
Allowed Values :
tag_zoffset
Description :
How far above a player's head their nametags are drawn, in world units
Allowed Values :
Any decimal value
bar_bgenabled
Description :
Determines whether or not to draw the white, rounded background of the health and armour bars.
Allowed Values :
0 to hide, 1 to show
bar_bgcolour
Description :
The color of the background of health and armor bars.
Allowed Values :
See: con_fillcolour
Note :
Alpha (AA) has no effect; bars are always 100% opaque.
bar_armourcol
Description :
The color used to represent armor in the armor bar above the name tag.
Allowed Values :
See: con_fillcolour
Note :
bar_armourxcol
Description :
The color used to represent overhealed armor (>100 armor) in the armor bar that appears above players' heads.
Allowed Values :
See: con_fillcolour
Note :
bar_healthcolmin
Description :
The color that represents 0 health for nametag health bars, which is blended between bar_healthcolmin and bar_healthcolmax.
Allowed Values :
See: con_fillcolour
Note :
bar_healthcolmax
Description :
The color that represents 100 health for nametag health bars, which is blended between bar_healthcolmin and bar_healthcolmax.
Allowed Values :
See: con_fillcolour
Note :
bar_healthxcol
Description :
The color used to represent overhealed health (>100) in the health bar above name tags.
Allowed Values :
See: con_fillcolour
***This Topic Quoting From : http://vcmp.liberty-unleashed.co.uk/forum/index.php?topic=2527.0***
SalmanAlvi.pk | ==SalmanAlvi.pk== | >>>Salman<<<
YT Channel: https://bit.ly/2YNg3IR
Offline Drakola
  • ThanKs To Allah FoR EvEryThinG!!
  • SA-MP: .DraK.
  • VC-MP: [VU_R]Drakola
Re: List of VCMP Commands | Vcmp_Config.txt
« Reply #1 on: November 25, 2018, 04:13:09 pm »
Great  :)
Credit: [VU]RoyStang
#VU4Life
Discord : Drakola#9012
Offline Unnamed
« Reply #2 on: November 25, 2018, 04:19:58 pm »
Nice!
Offline NSXtreme95
  • The cake is a lie
    • Invasión Latina
  • VC-MP: [VU]NSX
  • PAC ID: 20754
« Reply #3 on: November 26, 2018, 04:01:14 am »
Interesting salamandra
Offline Axan
« Reply #4 on: November 26, 2018, 10:39:02 pm »
Great useful topic. Thanks!
Offline PANZER24
« Reply #5 on: November 27, 2018, 10:33:21 pm »
That anti-aliazing thingy helped me too much in fact, thanks mate for your contribution :)
