Author Topic: Help! - VCMP Crash:  (Read 10025 times)
Offline Rz
  • Nothing is True. Everything is Permitted.
    • LK · Legendary Killers ·
  • VC-MP: [LK]Rorro.
Help! - VCMP Crash:
« on: February 12, 2019, 04:46:06 am »
bro its my skills not a aimbot if want check my pc plz come and see and i tell you who is aimbot has nick is Rorro he is aimbot not me
Kelvin Garcia Mendoza
Re: Help! - VCMP Crash:
« Reply #1 on: February 12, 2019, 06:29:14 am »
No has movido algún /setconfig antes de que ocurriera eso? Intenta borrar el ‘vcmp_config.txt’ (hazle una copia de seguridad) y vuelve a intentar.
El ‘vcmp_config.txt’ está ubicado en %appdata%/roaming/VCMP/04beta.
« Reply #2 on: February 12, 2019, 07:33:34 am »
Have you tried Gta VC single player? does it start or still the same error in single player too?
Offline SuriAttacker
« Reply #3 on: February 12, 2019, 09:12:46 am »
Try running gta-vc.exe in windows 98/XP compatibility mode, also don't forget to remove "gta_vc.set" file from the GTA Vice City User Files" folder in "My Documents". If there is no such file in the folder, you might want to try looking for the file in the Public Documents folder.  If you still face the problem, try messing around with the compatibility mode settings. Let me know the result.
« Last Edit: February 12, 2019, 02:07:03 pm by SuriAttacker »
Offline Rz
  • VC-MP: [LK]Rorro.
« Reply #4 on: February 12, 2019, 06:08:21 pm »
Hmmmm, no recuerdo. Fui a la carpeta que me dijiste y no está ese archivo. Sólo me aparece la carpeta "Crashlogs".
The "single player" works perfectly (translate)
I did what he told me and the error continues. (translate)
Offline NSXtreme95
  • The cake is a lie
    • Invasión Latina
  • VC-MP: [VU]NSX
  • PAC ID: 20754
« Reply #5 on: February 12, 2019, 07:29:23 pm »
Formatea todo como ultima opcion. stemen
Offline AgusTin
« Reply #6 on: February 18, 2019, 10:37:52 am »
Men tu vcmp esta bug entonces
Al no tener ese archivo el cual tiene la configuración  tendría que recrearse uno cuando entras al vcmp intentaste  reinstalarlo?
Offline PANZER24
« Reply #7 on: February 18, 2019, 10:08:26 pm »
turn on DEP, if it doesnt work (and even SP doesn't work) then there is a problem with the installation of your OS, RIP
