Author Topic: Login Problem  (Read 6161 times)
Offline SYSTEM X1
Login Problem
« on: February 06, 2009, 04:53:56 pm »
Hello,
I wanted to join your server today but failed to do so...
If I type in the /register command with any e-mail adress and password it tells me to play at least 10 minutes to be able to register;
But in order to play I have to be logged in,and in order to be able to log in I need to register,so what the...?Is this even possible?!
Re: Login Problem
« Reply #1 on: February 06, 2009, 04:57:28 pm »
How many times have you tried to rejoin? This has happened to me a few times and the solution was o keep trying to rejoin.
Offline SYSTEM X1
Re: Login Problem
« Reply #2 on: February 06, 2009, 04:58:51 pm »
Everytime I try to join it sais invalid password or login name;it even goes as far as telling me that my name already is registered,which in ANY case just can't be.
Re: Login Problem
« Reply #3 on: February 06, 2009, 04:59:47 pm »
just stay ingame for 10 mins and it will appear on /stats (if you dont logout). then try it again? :-\
Re: Login Problem
« Reply #4 on: February 06, 2009, 05:01:58 pm »
Wait. Are you registered already? or are you trying to register? It may be possible that your name is already registered, if it is, just try another name.
Offline SYSTEM X1
Re: Login Problem
« Reply #5 on: February 06, 2009, 05:02:13 pm »
I can't even GO ingame because it tells me to login and thats impossible with or without password so I can't logout - because I can't login -.-
Offline SYSTEM X1
Re: Login Problem
« Reply #6 on: February 06, 2009, 05:04:28 pm »
Ok for some reason it just worked,thanks anyway.But I've got another question,first how do you change the seat in a car and second how do you go into shooting position on a vehicle?
Re: Login Problem
« Reply #7 on: February 06, 2009, 05:06:22 pm »
You cant change the seat, but if you mean getting in as passenger press G and to shoot you need a micro SMG or an SMG and press H
Offline dannymc18
    • That´s how I keep cool:
Re: Login Problem
« Reply #8 on: February 06, 2009, 05:26:58 pm »
You were using a name that was already registered by someone else.  If the name isn't registered it wont ask you to login.
