Author Topic: Littlewhitey's stats signatures and userbars!  (Read 15778 times)
Offline Zamaroht
    • RaceWorld RPG
« on: February 27, 2008, 11:47:46 pm »
Stats Signatures
Example Signatures:
Get a signature as that is very very easy, just copy and paste the following code:
[img]http://zamaroht.popznet.com/lwsignatures/sig.php?name=NAME&&style=STYLE[/img]
Change NAME with your registered LW LVDM name. and with styles you can chose one of the following list:
The example code of the first signature is:
[img]http://zamaroht.popznet.com/lwsignatures/sig.php?name=[eVo]Zamaroht&&style=0[/img]
Example Userbar:
Get a userbar is very very similar, but the code changes a bit. It should be like this:
[img]http://zamaroht.popznet.com/lwsignatures/sig.php?name=NAME&&style=STYLE&&type==TYPE[/img]
Change NAME with your registered LW LVDM name. In styles you can chose one of the following list:
In TYPE, specify one of the following depending on the stats you would like to show:
  • 1   - kills
  • 2   - deaths
  • 3   - ratio
  • 4   - level
The example code of that userbar is:
[img]http://zamaroht.popznet.com/lwsignatures/sig.php?name=[eVo]Zamaroht&&style=1&&type=1[/img]
Many thanks to Popz for the website hosting and helping me with parsing the info from the api to php :)
* Zamaroht Gives a bag of cookies to Popz :D
About the styles:
Any gfx designer who would like to colaborate with new styles is welcome :D
There aren't restrictions with the size of the background, although we don't want a 1024x768 image as signatures, if you get what I mean :lol:
Would be nice if you could keep the signatures/userbars credit-free (I mean without any watermark with your name or bla, looks more cool for use), credits will be given to you in the styles list if your style gets accepted.
If you want to submit your style, first determine if it will be a signature or userbar:
Signatures:
Make sure to submit three files:
  • One without anything writen excepting Kills, Deaths and Ratio. example.
  • One of the same image as above but showing example info (so I can know the placement of where you are thinking to place the stats). example.
  • The ttf font you are using for display the stats. You will find it in WINDOWS/Fonts if you are using windows.
At the moment, in the signatures I'm incluiding:
  • Name
  • Kills
  • Deaths
  • Ratio
  • Playing Time
  • Player level
So include the placements of all this stats on the second image file.
Images can only be jpg or gif, in case you want to use transparency as in style 0 (not animated gifs).
Userbars:
  • One without anything writen just make sure to write littlewhitey server or something like that. example.
Images will most likely be jpg, although you can send gifs too (not animated ones).
Well I think that's it, enjoy! :D
« Last Edit: March 05, 2008, 03:46:34 pm by Zamaroht »
Offline mookla
Re: Littlewhitey's stats signatures and userbars!
« Reply #1 on: March 28, 2008, 03:49:39 pm »
heres some  8)
Offline Zamaroht
    • RaceWorld RPG
« Reply #2 on: March 28, 2008, 04:31:42 pm »
The letter turning/inclination can't be done with php :(
Offline blotto
« Reply #3 on: March 28, 2008, 05:14:58 pm »
Zam, the userbar styles can not be seen  ::)
mook, i luv ur works, how can i use 'em as my sig wid ma own stats/name?
Offline FaTaLiTy
« Reply #4 on: March 28, 2008, 08:25:48 pm »
Those gfx are hawt mook!
Offline mookla
« Reply #5 on: March 28, 2008, 09:47:29 pm »
thanx
well zam, what if u place text normally? reducing font size a bit, u can place it fitting the frame :)
Offline Popz
    • Visit me!
« Reply #6 on: March 29, 2008, 11:02:24 am »
yes you can! talk to me and i'll show you :)
Offline Zamaroht
    • RaceWorld RPG
« Reply #7 on: March 29, 2008, 03:19:40 pm »
Btw mookato, they have to be gif or jpg :)
Offline FaTaLiTy
« Reply #8 on: March 29, 2008, 03:35:17 pm »
They don't. My stats sig is png.
Offline mookla
« Reply #9 on: April 02, 2008, 05:59:56 pm »
* [eVo]mook spams
Offline blotto
« Reply #10 on: April 02, 2008, 09:19:40 pm »
mook u a gangsta on dis! luv ur works  :P
Offline Zamaroht
    • RaceWorld RPG
« Reply #11 on: April 02, 2008, 09:25:43 pm »
Ok I'll start doing them in a bit :P
Offline Deji
« Reply #12 on: May 19, 2008, 02:15:52 am »
Here is one. Didn't spend too much time on it really but I thought i'd post it anyway. Been busy with Scope getting everything perfect  ;D .
BTW.. [LF]Lorenzo (Me) = Good guy ;) take it easy!
Offline FaTaLiTy
« Reply #13 on: May 19, 2008, 02:51:30 pm »
heres some  8)
Can someone make a dynamic version of these plz :).
Offline TanaX01
« Reply #14 on: May 25, 2008, 10:01:33 pm »
Thank Admin Zamaroht  ;)
