Author Topic: New IRC commands.  (Read 3970 times)
Offline Ez
    • I dont like this:
New IRC commands.
« on: June 01, 2009, 10:03:50 am »
I added a new away system for IRC, these commands can be used in #lw.samp on FFSNetwork and are as follows..
?away [Reason (optional)] - Mark yourself as away with the specified reason, if none is given a default one will be used.
?away can also be used when your already marked as away.. It will automatically set it to the new reason for you.
?back - Mark yourself as back. (Can only be used when your away, DUH) - Tells you how long you were away for too.
EG:
<CuddleMuffin> Ez is now back from Sleep(ing with edit) after 8 hours, 2 minutes and 28 seconds
?isaway [user] - Check if a user is away and give you some details on them.
EG:
<@Ez> ?isaway KmanN
<CuddleMuffin> KmanN is currently away for cocks and has been away since May 31st 2009, 11.35pm. (21 minutes and 12 seconds)
It will automatically inform you if someone is away when you say their nickname in the channel.
EG:
<@[CJ]> eDiT doesn't even know
<CuddleMuffin> eDiT is currently away for penis and has been away since May 31st 2009, 7.50pm. (23 seconds)
