Author Topic: GTA San Andreas - Crash problems  (Read 131705 times)
Offline [eVo]Denon
    • My DJ website
« on: October 13, 2009, 10:28:21 pm »
Hey guys,
Thought some of you might had the same problem as me; The game randomly keeps on crashing!
Well, I have had it for a while, so I have found out some ways that MIGHT work for you.
My SAMP wont load anymore!? It just runs the singleplayer mode!
This is probably because you have the wrong GTA version.
You can easily download the downgrading patch in the link below;
http://forum.sa-mp.com/index.php?topic=63764.0
When I try do join a server, my GTA crashes!
This error comes because of a conflict with some values or files.
To avoid this, I recomend you not to install mods, if you have, you should remove them.
When I play, my game suddenly crashes
This goes allmoast the same as above. I again suggest you to remove your car/vehincle or other mods.
IF YOUR USING VISTA: The game has experienced some trouble at Windows Vista as far as I have heard.
What you should do, is run the gta_sa.exe (C:\Program Files\Rockstar Games\GTA San Andreas) file in Windows 98 Compatibility mode.
Another possible "fixer" is moving your GTA San Andreas folder to another area. Like out of the Rockstar Games folder.
Running it in Win 98 Compatibility mode helped me with most of my problems. (I use Windows 7)
Another good trick to solve some of the problems above, is to update your Video Driver.
I hope some of this might helped you.
I know there might be alot of spelling misstake, or bad writing/explinations here. Thats because of my lack english skills, so please forgive me for that!
Hugs and kisses(for the girls)
- [eVo]Denon
« Last Edit: February 07, 2010, 03:45:11 am by SUPERBAD »
Re: GTA San Andreas - Crash problems
« Reply #1 on: October 13, 2009, 11:37:58 pm »
Hey this is nice, I'll sticky it.
Btw, any idea why when using vista my game crashes if I pause?
« Reply #2 on: October 14, 2009, 02:46:51 am »
this has happened to me also.it stoped for some reason. try not to puse with esc instead use windows(key)
« Reply #3 on: October 14, 2009, 06:44:42 am »
I resolved the problem by not using vista for sa:mp lol
Offline iLz.tHO
« Reply #4 on: October 14, 2009, 10:42:35 pm »
WoW  :o nice topic! it happens when i had a weps mod, but i removed it some time ago
Offline [eVo]Denon
    • My DJ website
« Reply #5 on: October 15, 2009, 06:44:34 pm »
I suggest you just have to try run it in win 98 mod.  That fixed alot of my trouble.
And i remember way back, that its important not to ALT+TAB or pause while entering a 24/7 or ammu, my game crashed than.
Another thing that helped for me, was reistalling SA:MP, but i dont know if that was luck or not, because i guess its the gta_sa.exe thats fucked up, not the samp :p
Well, good luck :)
Offline UvH Clan
  • Ultra violent Hooligans
« Reply #6 on: October 17, 2009, 06:56:06 pm »
You might want to add that NVIDIAs latest  190-Driver-Series while using the x64 Version of Windows Vista causes that neither GTA SA nor SAMP will load up.
Offline Pluisje
  • Tranceaddicted
« Reply #7 on: March 01, 2010, 12:47:37 am »
this topic did solved the problem up by having less crashes or even never.
Offline MidNight
« Reply #8 on: March 09, 2010, 08:30:21 pm »
Hey guys,
- [eVo]Denon
get windows 7 it has no issues with gta sa vista is a buggy shit yo  :D
Offline Dodo0
« Reply #9 on: August 11, 2014, 07:43:12 am »
Lol this is from 5 years, i have the same problem i was playing on samp and it exit from the game and type crash.
And i have:
Windows 7
Overdose Effect mod
4 GB ram
1 GB drive (i don't know it's model i'll check it when i sit on PC)
I got GTA SA from my friend PlaYa by flash memory and i installed it on another disc than C i put it on desc named D.
If i removed Overdose Effect and do in GTA SA:
Right Click>Properties>Compatible >Windows 98 (Windows Me)
It will fix the problem?
« Last Edit: August 11, 2014, 11:31:42 am by DoDo0 »
« Reply #10 on: August 11, 2014, 11:30:46 am »
same problem here, compatibility mode for win 98 fixed it for me.
Offline Dodo0
« Reply #11 on: August 11, 2014, 11:33:26 am »
I will try thanks very much :D.
« Reply #12 on: August 11, 2014, 12:43:44 pm »
I got GTA SA from my friend PlaYa by flash memory.
Lol, Firstly it never got crashed with me, Never
Also i taked it from jojo and i have it about 4 years and there no such a crash.
Offline Dodo0
« Reply #13 on: August 12, 2014, 10:34:37 am »
Lol how i got it from you and it's the same game.
Btw a tried to make GTA SA to Windows 98/ Windows Me and opened samp it didn't crash, but when i closed it it types problem in samp it changed the GTA SA compatible to default.
« Reply #14 on: August 12, 2014, 10:45:14 am »
Can You type Exactly what is the proplem is :o or the Error? :-X :-X
