Author Topic: Class selection bug?  (Read 19706 times)
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
« on: July 08, 2012, 10:55:06 am »
Hello, after Mr.blewert changed some players skin to "Pizzaboy" (just for fun) , I'm having a problem to change my skin back.
Already tried :~
1- /class
2- F4
3- F4 and /kill
4- Reconnect.
ps. I want my old skin back! (modded)
Regards.
Offline Matz
Re: Class selection bug?
« Reply #1 on: July 08, 2012, 04:20:40 pm »
If I remember right, F4 and /kill doesn't working. You have to get killed by a player.
« Reply #2 on: July 08, 2012, 09:57:48 pm »
The F4 and then /kill is back and works again , as far as I know /class was removed due to some players who were abusing the command.
« Reply #3 on: July 08, 2012, 10:53:08 pm »
good choice, it was useful just for statswhores, if you wanna change, just /kill  :)
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
« Reply #4 on: July 09, 2012, 07:48:51 am »
The F4 and then /kill is back and works again.
That's great.
Indeed. It's a good choice to delete taht communt. :P
It supposed to work well.
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
« Reply #5 on: July 09, 2012, 08:34:33 am »
EDIT : No, it doesn't work. Tried.
ps. I didn't meant to double-post. I accidently clicked "Quote"
« Last Edit: July 09, 2012, 08:36:46 am by [B]iDaMn »
Offline enO_suhpyrG[R]
  • Slice Master of Property
« Reply #6 on: July 09, 2012, 03:45:44 pm »
How could /class command be abused? It used to set your health to only 1 hp so you could be easily killed.
« Reply #7 on: July 09, 2012, 05:02:46 pm »
After 10 seconds you can change the skin ... i don't think could be abused.
« Reply #8 on: July 09, 2012, 05:30:53 pm »
simply if the runner on low health was far enough from the chaser and kept running while he already typed /class, after 10 seconds he managed to escape, whereas without that cmd he would have died . Or even easier, when they are in a vehicle and type it, it's rly easy to escape.
It often happened to me that some statswhores or runners abused it to escape.
Anyway they did a good thing removing it, let's just be happy about it, a possible abuse solved  ;)
« Reply #9 on: July 09, 2012, 06:27:57 pm »
Nubs, this dood is obviously bug'd. If he said; "...F4, /class, /kill, reconnect ...don't work..." then it doesn't. Also if F4 and "...class.. on next death..." is not good for someone than that someone is not a someone for sa:mp.
ps. iDamn, just /re urself if any admon will be online to set your skin. Problem solved, you're welcome.
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
« Reply #10 on: July 10, 2012, 08:27:13 am »
Shatap nub. and yeah thanks.
And yes, as u can read Quickplay post, they can abused while dueling too. And make the opponent bugged in DA too.
« Reply #11 on: July 10, 2012, 10:28:05 am »
basically it was used like a teleport command. If the person that was low on health was somewhere save, like in a bank, ammu, checkpoint or ahead in a car, they could use the command to practically teleport away from the attackers, as the respawn during reclassing almost works the same way as respawning in general, just with a less important option to change your skin, and without adding a death to your stats.
This command was for statswhores that couldn't bear being killed once too much for their 'perfect' polished stats.
Now i know what one could say - hey, if they don't wan't to be killed let them - not everyone want's to die. Well, this is mainly a death-match game mode with some additions, and if people don't want to die they'd go and play on a trucking server. There have been rules and conventions here ever since: at first don't abuse commands for stats padding, secondly no teleports - teleports suck shit, third: If you can't accept being killed you shouldn't kill either, so shut up and die.
Lastly, i experienced that most of the players that abused this command in the described way were statswhoring regulars. Normal newbies would /q or hide in a bank/ammu/checkpoint or run/drive/fly to avoid death.
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
« Reply #12 on: July 10, 2012, 10:56:23 am »
Experts experience. :D
« Reply #13 on: July 10, 2012, 11:12:08 am »
Whoever removed it - good job :)
Changing class is not obligatory, if you don't want to die you can stick with the one you are already using ;)
« Reply #14 on: July 10, 2012, 03:18:40 pm »
gryphus will cry :'(
