Author Topic: New rig  (Read 18961 times)
Re: New rig
« Reply #15 on: June 07, 2014, 07:03:33 pm »
Well i'm going to set it up all by myself (whish me luck  :D). I don't have a desktop computer, just a shitty laptop which is giving me a lot of trouble lately. It will not be just for games, I just want to set up one that will last me at least 3 years without any issues or other upgrades. I'm not that fussy with the graphics being high, all I want is a good gameplay without lag and a good framerate.
What @BikeDriver suggested me seems pretty cool. I think I'm buying that. A 120gb sdd should be enough for me i guess.
Thanks a bunch for the help and sorry for the late reply.
Re: New rig
« Reply #16 on: June 07, 2014, 07:19:16 pm »
Holy shit, forgot the PSU.
1x be quiet! Pure Power BQT L7-630W, PSU - € 69,90*
what do you think about this one? http://www.pccomponentes.com/corsair_cx750_750w_builder_series_80_plus_bronze.html
Offline Jellyfish
Re: New rig
« Reply #17 on: June 07, 2014, 08:28:15 pm »
The Corsair CX series is quite low quality, hence why it's cheap and boutique builders cram it into their systems.
A good alternative to that is this.
Offline Jellyfish
Re: New rig
« Reply #18 on: June 07, 2014, 08:57:25 pm »
Here's my take on the build, if you haven't ordered any of the parts yet
CPU: i7 4770k - €269
CPU Cooler: Coolermaster Hyper 212 EVO -  €30
Motherboard: Gigabyte G1 Sniper -  €145
RAM: - G Skills Ripjaws -  €79
Storage: - SSD and HDD - €72 and €45
Graphics card: GTX 770 4GB - €330
Case: - Thermaltake Urban -  €60
Total: €1030 (minus the power supply)
Couple of things about this build
- Newer motherboard (z97) compatible with the new generation of Intel CPUs (devils canyon/broadwell) in case you want to upgrade down the line
- RAM is only 8GB, which is just the right amount if you're only gaming. You can add one 1x4 stick if you feel the need but this should be just fine
- 4GB of VRAM in the graphics card, as Watchdogs just proved a little while ago, VRAM is now becoming a bottleneck for most people in the newer games, and it'll only be used more and more from now on.
The entire thing links to local Spanish stores, so you should have no trouble ordering parts or even replacing parts. Only used 2 (Amazon and Alternate.es) for the sake of convenience.
One thing you could do improve this is to wait till the end of June for the i7 4790k and get that, should offer you greater performance and overclocking potential for about the same price. To drive down the costs of the build, simply get a cheaper variants of the motherboard/GPU/Case and get a i5 4670k (or the 4690k at the end of this month). The i7 offers negligible gaming performance over the i5.
« Last Edit: June 07, 2014, 09:09:03 pm by Your Alcoholic Dad »
Re: New rig
« Reply #19 on: June 18, 2014, 04:01:58 am »
there's my baby:
specs:
PSU: Be Quiet Pure Power L8 CM 630W Modular
RAM: G.Skill Ripjaws X DDR3 1866 PC3-14900 16GB 2x8GB CL10
GRAPHIC CARD: Gigabyte GeForce GTX 760 OC 4GB GDDR5
PROCESSOR: Intel Core i7-4820K 3.7Ghz Box
MOTHERBOARD: MSI X79A-GD65 8D
HDD SSD: Samsung 840 Evo SSD Series 120GB SATA3
              :  WD 1TB
DVD RW: Samsung SH-224DB Grabadora DVD 24x OEM Negra
COOLER: Scythe Mugen 4
CASE: Zalman Z11 Plus Roja
thank you all once again
« Last Edit: June 18, 2014, 04:04:41 am by Shizalk »
Re: New rig
« Reply #20 on: June 18, 2014, 07:11:41 am »
Had fun installing the Mugen, yes? :))
Re: New rig
« Reply #21 on: June 18, 2014, 07:34:50 am »
nice one, maybe you should do some cable management though :D
Re: New rig
« Reply #22 on: June 18, 2014, 09:08:40 am »
Looks nice,well done,shiz. :)
Offline [V]Cash[iA]
Re: New rig
« Reply #23 on: June 18, 2014, 01:35:20 pm »
Last picture, inception! :D lel
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
Re: New rig
« Reply #24 on: June 18, 2014, 02:13:28 pm »
Gimme it! Gimme! I want it! EPIC
Re: New rig
« Reply #25 on: June 18, 2014, 03:12:32 pm »
Btw.. make sure that you have connected the SSD and the HDD to SATA 3 ports. They should be white and label SATA1_2 or similar.
Re: New rig
« Reply #26 on: June 18, 2014, 03:17:45 pm »
Also make sure that you have connected the RAM dimms to different channels for dual channel mode.
From the left to the right the order is:
Channel1_1, Channel1_2, Channel2_1, Channel2_2 |||| CPU |||| Channel4_2, Channel4_1, Channel3_2, Channel3_1
The manual recommends one of the following in order to enable dual channel:
Channel1_1, Channel2_1
Channel1_1, Channel4_2
Channel1_1, Channel3_1
« Last Edit: June 18, 2014, 03:21:58 pm by BikeDriver »
Re: New rig
« Reply #27 on: June 18, 2014, 06:13:14 pm »
yea..i had a great time :D I dind't expect it to be so big. I felt kinda stupid trying to figure out how to put the damn fan.
I know, it's all messed up now. I need to make sure that everything works as expected first.
The display is not turning on during start up. I checked all cables to be sure everything was fine, but for some reason it doesn't turn up. The fans of the graphic work fine and that made me think that the graphics might not be the problem.
I didn't know there was an order for connecting RAM dimms, I just put one on each side of the processor (blue slots). I'll check that out as soon as I get home.
Re: New rig
« Reply #28 on: June 18, 2014, 06:39:33 pm »
That might already be your reason.
Also check if you have connected the additional power connectors of the graphics card (1x 6 pin, 1x 8 pin) and the upper power connector of your motherboard (8 pin)
« Last Edit: June 18, 2014, 06:41:08 pm by BikeDriver »
Re: New rig
« Reply #29 on: June 18, 2014, 11:21:52 pm »
it worked  :D thanks a bunch
