Author Topic: help help and help  (Read 7862 times)
Offline Azure
  • VUholic
help help and help
« on: May 03, 2016, 07:18:02 pm »
i want to enter server but says version downloaded by server failed to download please help
Offline CyberNetiK.bLood
Re: help help and help
« Reply #1 on: May 03, 2016, 07:40:06 pm »
Offline Azure
  • VUholic
« Reply #2 on: May 04, 2016, 10:38:14 am »
Didnt work
Offline Hunters
  • Fover A King
    • http://Kingz-clan.gq/forum
« Reply #3 on: May 04, 2016, 10:42:07 am »
I got that same problem   :-\
« Reply #4 on: May 04, 2016, 11:26:52 am »
try this,
 Press windows+R key then type "appdata/local/vice city multiplayer then rename the this folder name from 04rel003 to 04rel004
then try to join
Offline krystianoo1
« Reply #5 on: May 04, 2016, 11:38:35 am »
try this,
then try to join
dont
do
this
« Last Edit: May 04, 2016, 11:43:07 am by krystianoo1 »
« Reply #6 on: May 04, 2016, 11:53:09 am »
try this,
then try to join
dont
do
this
Offline krystianoo1
« Reply #7 on: May 04, 2016, 12:19:34 pm »
Presumably and probably none of this will help you (the rename might work if it won't crash you but it makes you play on an old version and you will encounter a lot of bugs and glitches so don't even think about doing it) so do this:
Go to http://u04.thijn.ovh/
Download 04rel004
Rename the file (rar/.7z) you downloaded to 04rel004.
Right click the .rar/.7z and click extract to 04rel004/
Copy the folder 04rel004
Go to %appdata%
Back out to Appdata, click Local (so C:\xxx\xxx\AppData\Local)
Go to Vice City Multiplayer
Paste the folder then, replace all if possible.
Try joining.
Offline Foxtrot
« Reply #8 on: May 04, 2016, 01:23:36 pm »
[RK]SMD_ASSHOLE, please delete your stupid signature unless you want a forum ban. Thanks.
« Reply #9 on: May 04, 2016, 02:48:33 pm »
Cybernetik, I already removed your post before. Please stop. I also removed your forum title as you are not Management. Modified your signature to be more appealing to the forum [RK]SMD_ASSHOLE.
« Reply #10 on: May 04, 2016, 05:51:14 pm »
Wt you mean delete signature??? I had not get it  or you mean its a large???
Offline Azure
  • VUholic
« Reply #11 on: May 04, 2016, 06:44:43 pm »
krystianoos way worked :D
u can lock the topic
