Author Topic: Problem  (Read 37065 times)
Offline Cr4zy
Problem
« on: January 20, 2008, 02:16:05 pm »
I have problem to fine Littlewhitey's server:
I never play this server... :'(
Offline Simon
  • Retired
  • SA-MP: [CP]Simon
Re: Problem
« Reply #1 on: January 20, 2008, 02:25:48 pm »
That's the wrong server ip, try adding 83.133.126.170:7777 to your favourites. If it still doesn't work then post your IP and we'll check if it's banned.
Offline Cr4zy
Re: Problem
« Reply #2 on: January 20, 2008, 03:34:44 pm »
Again,lol i never play littlewhite i never banned from that server :'(
Offline kenny01
Re: Problem
« Reply #3 on: January 20, 2008, 05:29:41 pm »
Do any other servers work for you?
Offline Cr4zy
Re: Problem
« Reply #4 on: January 20, 2008, 05:57:45 pm »
yes..
Offline kenny01
Re: Problem
« Reply #5 on: January 20, 2008, 07:56:35 pm »
Could you open command line (cmd) type "tracert 83.133.126.170" and paste the output here?
Offline Cr4zy
Re: Problem
« Reply #6 on: January 20, 2008, 09:23:25 pm »
Hire I tipe this: tracert 83.133.126.170
And:
maybe but I not remember.. :-\
« Last Edit: January 20, 2008, 09:25:15 pm by Cr4zy »
Offline LorenXo
    • do you like them too?
Re: Problem
« Reply #7 on: January 20, 2008, 10:13:37 pm »
I think what he was asking was for you to go start>run and type "cmd" (without quotes), then type "tracert 83.133.126.170" (again without quotes) in at the prompt and post back the results it gives. (It should take a few moments to complete)
<eDiT> what is intellectual
Offline Cr4zy
Re: Problem
« Reply #8 on: January 20, 2008, 10:59:19 pm »
I do that and:
now what.... ;D
Offline LorenXo
Re: Problem
« Reply #9 on: January 20, 2008, 11:40:58 pm »
I'm not sure if he'll need the other info but the bit you've blanked is kinda the important bit. I realise that the first bit will be your ip but the later bits are more useful. You can PM Simon or me and I'll relay it to him.
Of note, those are pretty high times which could be causing issues.
If you can, try making sure that no other computers are connected to the internet at your house and that you're not running any other programs which use the internet in the background (specifically peer-to-peer).
